#1 2025-04-01 18:24:09
jaz89
[FIXED] Boron netinstall script error
Hello, when I finish to install debian 12 netinstall and then try to install bunsenlabs boron with the netinstall script I get this error:
./install: line 169: curl: command not found
######## ERROR ########
Debian repository seems to be offline
Unable to continue without working Debian repository
now exiting...
#2 2025-04-02 00:15:33
Re: [FIXED] Boron netinstall script error
Hi @jaz89 thank you for catching this bug.
The fix has now been uploaded, so could you try downloading the tarball again, and running the script one more time?
It's probably safer if you delete the boron.tar.gz you currently have ( 'rm boron.tar.gz' ) before running the wget command again.
Thanks!
#3 2025-04-02 20:03:59
jaz89
Hi John, it's working and I was able to finish the bunsenlabs installation without errors. Thank you!
#4 2026-01-13 11:39:38
Siera_Cortney
I was just about to run a netinstall on a spare machine and probably would have bumped into the same curl error. Really appreciate how fast the dev team stays on top of these bugs.
