#1 2021-01-27 17:01:28
blackup
[SOLVED] client-list-combined-menu
Greetings, BL community.
I am very satisfied with this distro and it still keeps me away from hopping. How much I like it so far can be described in wallpaper and custom vscode theme that I made, using BL color scheme. :-)
Back to subject: I had to reinstall it couple days ago due to ssd replacement.
Screenshot 1 is small collection of things I do after installation.
Screenshot 3 is bonus thing - disabling conky.
Screenshot 2 shows my issue.
https://imgur.com/a/gbKc4UU
These are the only things I edited.
I haven't experience such thing during my previous ride. Already spent almost 2 hours googling solution without success. It keeps me away from today's obligations so I am forced to ask if you guys have any idea what is causing this?
"It's not about kill. It's about hunt."
#2 2021-01-27 17:08:27
malm
Wayland Compositor developer
Re: [SOLVED] client-list-combined-menu
^ could you describe the issue. I don’t understand what it is
#3 2021-01-27 17:21:38
blackup
Hi, Malm.
I'll try to be more precise. Screenshot 2 shows menu that I called with middle mouse button. It's way lighter than jgmenu and there are no borders between fields. It's a small visual issue but still a bit annoying. :-)
#4 2021-01-27 18:12:03
rbh
That is Windows client menu, usualley called by Super+Tab. if you do not like it, do not use it!
Can you start Jgmenu?
In terminal, run command jgmenu_run.
With mouse call it with right click.
Default keys are Super+Space.
Edit:
File ~/.xbindkeysrc, is the file where you set shottkeys.
#5 2021-01-27 19:19:38
blackup
Hi, rbh.
Thank you for taking time for this. I like this little menu and it's function. That's why I use it regularly. But! I installed BL and after first boot everything was alright. On 2nd boot it changed it's look and I am curious what caused it.
Here you can compare original and mine:
https://imgur.com/a/j1bX1lw
During first run I didn't do anything except applying screen tearing "fix". Any idea of eventual solution?
#6 2021-01-27 19:50:25
Huh,  Is it part of the gtk Openbox~! theme?  Did the color change after clicking on the item?  If you click on the others, do they change as well?
Edit* Just noticed the separators are gone??  hmm.
If you change themes does this happen?
#7 2021-01-27 20:08:38
I'd guess this must be part of openbox theme.
#8 2021-01-27 20:09:02
rbh
But now you are showing another menu than last. Now you are showing the window menu, called by Alt+Space.
As sleekmason wrote, the look of those menus is configured by obconf and laxapperance.
Have you done a backup of your theme by the Blob Themes Manager(under BL Utilities)? then just read back the backup.
Else, try to change theme and then change back.
#9 2021-01-27 20:58:09
blackup
@rbh
On Screenshot 1 in my first post, I showed jgmenu menu just to compare it's background color with menu that I call with middle mouse button. jgmenu has darker background.
I noticed changing theme doesn't always work even if I do "Preferences - Reload GTK" and "Preferences - Openbox - Restart" via jgmenu. OB theme changes while gtk remains the same or vice versa. In such case, I need to reboot for desired theme to get fully applied. I got no any custom theme or one that I downloaded from the internet. All this is happening with themes that comes with BL.
This is my current setup:
https://imgur.com/a/zgfu9Eb
"Desktop" menu is still messed up, as you can see. Restoring theme with BLOB doesn't help.
I did reinstall the system two times earlier today and I experienced the same problems with both "desktop" menu and changing themes, all this on 2nd boot. During 1st boot, everything was normal which makes me think that I ruined something.
The only things I did to affect the system in any way is on this list.
### if keys error
wget https://ddl.bunsenlabs.org/ddl/BunsenLabs-RELEASE.asc
sudo cp BunsenLabs-RELEASE.asc /etc/apt/trusted.gpg.d/
### screen tearing:
/etc/bunsen/compton-startup #lines 40, 61, 114
--backend glx --vsync opengl-swc --paint-on-overlay
### touchpad on/off toggle
# /home/blackup/.config/openbox/bl-rc.xml
<keybind key='W-S-l'>
    <action name='Execute'>
        <command>bash -c "synclient TouchpadOff=$(synclient -l | grep -c 'TouchpadOff.*=.*0')"</command>
    </action>
</keybind>
Also in /.config/bunsen I did comment line 96, excluding conky from autostart.
#10 2021-01-27 21:11:12
The compositor.  Compton . .?  but that fixes your screen tearing right? Can you disable the compositor completely to see if that is the issue?  If so, maybe an adjustment can be made.
#11 2021-01-27 21:26:48
blackup
Hi, sleek.
I disabled compositor. This is what I got.
https://imgur.com/a/8QZNFE2
Screenshot 2 is when I sync jgmenu with gtk theme.
Screenshot 3 is when I sync jgmenu with openbox theme.
Screenshot 1 is how desktop menu looks like in both cases.
Also, you can notice jgmenu isn't spawning properly. This time it happened when I disabled compton but it also happening randomly when I reboot the system. But that's another story and I can fix that.
Btw, yes, those couple of lines solve screen tearing.
#12 2021-01-27 21:36:12
rbh
The lines for "touchpad on/off toggle", seems suspicious.
What is it suposed to do? Allow you to toogle the touchpad on of? How if so? It does not seems to make any difference on my laptop.
I have som lines to toggle touchpad off while typing, but in autostart:
# ~/.config/bunsen/autostart
## Configure touchpad. See 'man synaptics' for more info.
## (Now might be using libinput instead of synaptics.)
synclient VertEdgeScroll=1 HorizEdgeScroll=1 TapButton1=1 2>/dev/null
## Disable touchpad while typing
syndaemon -i .5 -K -t -R -d &
You can try to copy default bl-rc.xml from skel, if changing theme back and forth does not help:
mv ~/.config/openbox/bl-rc.xml ~/.config/openbox/bl-rc.xml.bak
cp /usr/share/bunsen/skel/.config/openbox/bl-rc.xml ~/.config/openbox/bl-rc.xml
#13 2021-01-27 21:46:57
blackup
Our autostart looks the same.
# ./config/bunsen/autostart
lines 58-63
I found this touchpad on/off toggle thing on this forum during my early days with BL like 1 month or so ago. :-) I use super-shift-l to toggle and it does work after you restart Openbox (if I am not wrong), to apply it.
I am so tempted to reinstall the system one more time to see if and when my problem occurs. Because, once again, everything works nicely during 1st boot.
This is my /.config/jgmenu/jgmenurc:
tint2_look          = 0
csv_cmd             = apps
position_mode       = pointer
menu_width          = 134
menu_padding_top    = 24
menu_padding_right  = 0
menu_padding_bottom = 0
menu_padding_left   = 0
menu_radius         = 1
sub_spacing = 6
item_margin_x       = 1
item_margin_y       = 1
item_height         = 21
sep_height          = 4
sep_halign = right
font                = Sans 10
icon_size           = 0
arrow_string        = ›
arrow_width         = 8
color_menu_bg = #2B454F 100
color_menu_border   = #304D59 100
color_norm_bg       = #C8CFCB 00
color_norm_fg = #d3dae3 100
color_sel_bg = #bc4b4f 100
color_sel_fg = #ffffff 100
color_sel_border = #bc4b4f 100
color_title_fg = #cc666a 100
color_title_bg = #2B454F 100
color_title_border = #2B454F 100
color_sep_fg = #535353 100
sep_markup =
hover_delay         = 30
csv_name_format     = %n
menu_border = 0
I wonder if I ruined something here. The only line I sometimes edit is line 3 (position_mode = pointer) and I do it by removing or adding couple of spaces on same line, just to be able to save the file, and it does "fix" the wrong jgmenu position when called.
#14 2021-01-27 22:39:33
blackup
Okay, so I reinstalled the system. Everything was okay. My only intervention before going thru bl-welcome script was this:
to avoid that key error during update (this was unnecessary back in December).
I waited till it's done, called desktop menu and got this:
https://imgur.com/a/TKicnUh
I am still not sure why but at least I know my usual first few steps as fixing screen tearing didn't cause this.
Thank you guys for your readiness to help. One of main reasons why I stick to BL is this lovely community. Such minor issues won't keep me away from being a happy BL rookie. :-)
#15 2021-01-27 22:53:44
rbh
It does not work on my laptop. But "synclient TouchPadOff=0" and "synclient TouchPadOff=1"works...
I hope you mean "worked nicely during 1st boot, after reinstalling"...
Before you wrote you had not tuched it...
There is some possible values for "position_mode="; fixed, ipc, center and pointer
If you have setting "= pointer", it shall show the menu under the mousepointer. If you edit ~/.config/jgmenu/jgmenurc, jgmenu will reload. It seams that jgmenurc does not care if you add spaces before or after "=". Some configfiles is sensative for that. It is betetter to stick to original layout. You can instead reload jgmenurc:
$ source ~/.config/jgmenu/jgmenurc
You can contemplate why jgmenu does not load configfile correct...
#16 2021-01-27 22:56:52
rbh
If changing theme and cange theme back agin, or copying default bl-rc.xml, does not fix appearance, I'm out of ideas.
#17 2021-01-27 23:11:12
The only further idea I have, would be to copy the Openbox theme from /usr/share/themes to ~/.themes (Make the folder if it isn't there.) The gtk theme too if you want.
The system will read from this file first, and if things work correctly, it means . . . another step in the right direction.
#18 2021-01-27 23:15:29
blackup
Hey, rbh.
I set the shortcut, save the file, restart Openbox via jgmenu and shortcut becomes active.
Yes that's exactly what I mean. Everything works fine but looks like things becomes messy after system update.
I did a bit of testing and realized themes doesn't change fully. I change both gtk and openbox theme and restart/reload them via jgmenu. Jgmenu keeps the format of previous theme while everything else is changed. You can see the pattern here on this link. I added screenshot descriptions.
https://imgur.com/a/cavEeOZ
I hope this helps a bit.
@sleek
I did what you suggested but nothing changed in my favor so I believe some of updated packages are causing this.
#19 2021-01-28 08:47:18
rbh
So, then you have to investigate that further.
1. After installing, do not apply any updates. Just check system and reboot.
2. Apply systemwide updates (apt update, apt upgrade). Check and reboot. When bl-user-setup, pops up a messsage about copying new userconfigs, just kill it. Reboot check.
3. Now first, let bl-user-setup copy all new user configs. (Run command in terminal) check  appereance, reboot and check.
If still ok. edit configfile, apply your chenges.
Remember, no one else gets a messy system after upgrading new installation. So, most likely, it is something you have done to the system.
And that is why you have menu setting "Sync theme with...", on Preferences => Jgmenu =>.
#20 2021-01-28 09:19:02
blackup
Okay, I will try again and follow these steps. Btw, just to be sure you understand me, by "changing theme" I mean switching between them. I like default theme very much so I am not doing any modifications.
I reinstalled, restart to boot for first time, ignored bl-welcome and just restarted again. Then on 2nd boot I added that key, did sudo update/upgrade and this is where I am right now.
https://imgur.com/a/vezn1JQ
Which one to choose?
Edit:
I went "Y", update finished, restarted the system and this is what I got:
https://imgur.com/a/SwdA8E7
So yea it gets messy after update. I did nothing in between.
Followed steps you suggested. Killed bl-user-setup message, restarted, then I got this:
https://imgur.com/a/VAFKKSD
After browsing BL forum meanwhile and I found this link:
https://forums.bunsenlabs.org/viewtopic.php?id=7271
Maybe some of these are one to blame?
