Posted here: Tutorials > Upgrading from Helium to Lithium.
Constructive suggestions are welcomed, but please remember that "Tutorials" is not the place for Help requests ![]()
Artwork on DeviantArt «» BunsenLabs on DeviantArt
I can't find anyting left out or that should be phrased otherwise... Thanks.
Edit:
https://deb.debian.org/debian-security, is redirected to http://security.debian.org/debian-security/. Is it not better to use that adress instead?
My mirror and I think no mirrors carry the security packages. People choosing a close mirror, can look in vain for the security packages...
https://deb.debian.org/debian-security, is redirected to http://security.debian.org/debian-security/. Is it not better to use that address instead?
Yes, security upgrades are handled differently, but I guess the deb.debian.org url is safe to use.
As to the https > http redirect, I suppose it's always possible debian security might support https some time in the future, and the redirect changed, so no harm in going by that route now?
(In fact, while https does add a little bit of extra security, it's not such a huge difference, because debian packages are checksum-validated anyway.)
rbh wrote:https://deb.debian.org/debian-security, is redirected to http://security.debian.org/debian-security/. Is it not better to use that address instead?
My mirror and I think no mirrors carry the security packages. People choosing a close mirror, can look in vain for the security packages...Yes, security upgrades are handled differently, but I guess the deb.debian.org url is safe to use.
I was not writing about the technical aspect. Of cource, there is no technical problems with using adress https://deb.debian.org/debian-security.
I raised the question of claryfying that security packages is handled differently. For them who want to replace https://deb.debian.org/debian with closer mirror, they shall not try to replace https://deb.debian.org/debian-security, with the same mirror. It will fail.
Using https://deb.debian.org/debian-security in the tutor, might lead some astray.
Yes, a note that it's necessary to check if an alternative security upgrade url is actually available before trying to use it... would be a good idea.
But:
I'm not sure I grasp the issue here - what are you suggesting would be better?
Tutorial updated to clarify the use of backports.
Why invite people to an goose chase? Time is too valuable to vaste on doomed tasks. https://www.debian.org/mirror/, lists what is mirroring. debian-security, is not listed, is not mirrored.
But:
rbh wrote:Using https://deb.debian.org/debian-security in the tutor, might lead some astray.
I think, best would be:
To change [comment: note, change instead of edit] the Debian repos, edit /etc/apt/sources.list. Depending on which mirror (https://www.debian.org/mirror/list) you use, change the sources from:
deb https://deb.debian.org/debian stretch main contrib non-free
deb https://deb.debian.org/debian stretch-updates main contrib non-free
to
deb https://deb.debian.org/debian buster main contrib non-free
deb https://deb.debian.org/debian buster-updates main contrib non-free
And
deb http://security.debian.org/debian-security stretch/updates main contrib non-free
to
deb http://security.debian.org/debian-security buster/updates main contrib non-free
(debian-security are not mirrored like man debian and still does not support https.)Last edited by rbh (2020-08-20 09:51:21)
Yes, that sholud be added.
Maybe after:
"Disable your backports sources before a dist-upgrade to see if the packages are still required." add: Disable by adding "#" first on the row for the backports source.
Now I found it:
The debian-security/ archives contain the security updates released by the Debian security team. While it sounds interesting to everyone, we do not recommend to our users to use mirrors to obtain security updates and instead ask them to directly download them from our distributed security.debian.org service. We recommend debian-security not be mirrored.
https://www.debian.org/mirror/ftpmirror
I have not found anyone not following that.
@rbl I'm not yet totally convinced that
would be an inappropriate url to recommend to users.
1) deb.debian.org is an official service (a debian subdomain), not a third-party mirror, and Debian can presumably be relied on to maintain the redirect correctly. I don't think the warning about not using mirrors for security updates would apply here. Yes, the above quote is quite specific about using security.debian.org, but that page is advice for people considering setting up a new third-party mirror, not for users. Why would deb.debian.org provide a security mirror if another part of Debian were deprecating it?
2) Security updates are now only provided via http protocol, but if that changed in the future then users would have to update their sources once more to use it. With the https://deb.debian.org url, the redirect can be trusted (I think) to be correctly changed without users having to do anything.
I see now what you were saying. I thought you meant that some mirrors did not provide security updates, hence my reply:
Was actually meant to be toungue-in-cheek. ie "Don't try to add mirrors that don't exist."
At least the information:
https://deb.debian.org/debian-security, is not mirrored.
^Yes, that would be appropriate to add, for sure.
We're just providing default settings here for new users to copy. A reminder about mirroring, for people who want to go beyond that, would be helpful. ![]()
it works! oh happy day!
Success for me also. All programmes and separate Home partition preserved, as @ovum says "happy days". Time to donate.
volvox.biz a very tedious daily account of life during covid,
Time to donate.
Always appreciated, thanks!
A small thing....
A fresh install would have given me a hostname lithium, Doing the upgrade it is still helium. How would I change the hostname and could there be bad consequences?
sudo hostnamectl set-hostname new-host-nameopen the /etc/hosts file and replace the old hostname with the new-host-name
it just happens I just did it on an install the failed to ask for a hostname, which is bad form on the installers part.
test with
hostnamectl8bit
One more small thing...
On my Helium I didn't have fortune cookies so I have tried to add them but all I get is an empty text box so I guess I am missing where to find the sayings. Where does that information need to go?
I have searched the forum but cannot find the answer, sorry.
So a pointer please? Thanks
Install package bunsen-fortune, enable in autostart.
You can also add fortunes, BL or otherwise directly to conky!
${execi 3114 fortune -s | fold -s -w24}Depending on the size/shape, you may need to change the width:)
