#1 2016-04-12 01:01:22
Peregrino69
[SOLVED] Autossh failing
More weirdity...
I'm running a permanent reverse SSH tunnel to RasPI at home using autossh. To have it starting automatically without logging in on Waldorf I just added this to /etc/rc.local:
# Start autossh script, output errors to log
/home/pgrino69/bin/raspitunnel > /home/pgrino69/log/raspitunnel.log 2>%1
The actual script is:
set +e
SSH_OPTIONS=" -i /home/pgrino69/.ssh/id_rsa"
export AUTOSSH_GATETIME=0
export AUTOSSH_PORT=0
nohup autossh -f -- $SSH_OPTIONS -o 'ControlPath none' -R 15069:localhost:22 pgrino69@raspi1 -N 2> /home/pgrino69/logs/autossh_errors.log
exit 0
Now I'm trying to do the same on BL, only diff is the port number. And that fails. Autossh starts nicely, but RasPI won't start listening. If I run the script after login, it works just fine. I tried to stick this to /etc/init.d/, no luck.
What on earth??? Do I have to figure out how to do this as systemd service???
#2 2016-04-12 03:58:27
tknomanzr
BL Die Hard
Re: [SOLVED] Autossh failing
Yeah that kind of sucks about systemd. I went through a ton of headaches figuring out how to automount a sshfs mount. I finally figured out that the easiest way to go about it is to set it up in /etc/fstab. Systemd will then figure out the .mount and .automount unit files for you. For network mounts, be sure the _netdev option in /etc/fstab is listed. I have a post in Scripts, Tutorials and Tips where I built the mount points up as unit files but that method was considerably buggy. /etc/fstab was a better option though gvfs seemed to pick up the fuser mount and I would end up with a double mount. Plus, Debian does not seem to do well with the _netdev specifier in /etc/fstab. It does not unmount any network shares prior to shutdown which leaves you with a hung service for a minute and a half on each shutdown.
It would appear that I have lost the /etc/fstab stuff when my sid system blew up recently. I will have to rebuild it and push updates out go both git and the walkthrough I have posted on these forums.
The arch wiki should be a good place to start if you intend to go this route. I am pretty sure in a systemd system you will be unable to automatically mount stuff outside of the context of systemd. I mean, you can manually mount ssh stuff via terminal but automounting is not as simple as just executing said script. Also, getting keys to work is just a full on headache.
#3 2016-04-12 19:06:43
Peregrino69
Oki, so I need to figure out systemd services. This isn't a network share, this is just a permanent tunnel - I'd assume you don't mount those even with systemd smile
BTW it'd be nice if you linked the post you're referring to smile
#4 2016-04-12 19:27:44
Yup.
big_smile
Here's your starter for 10:
# /etc/systemd/system/raspitunnel.service
[Unit]
Description=Raspberry Pi ssh tunnel
Wants=network.target
After=network.target
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/bin/sh -c '/home/pgrino69/bin/raspitunnel > /home/pgrino69/log/raspitunnel.log 2>%1'
[Install]
WantedBy=multi-user.target
I'm sure you can do better...
See systemd.unit(5) & systemd.service(5)
To start the .service on boot, use:
sudo systemctl enable raspitunnel
To stop it, use:
sudo systemctl disable raspitunnel
See systemctl(1)
#5 2016-04-12 19:52:32
tknomanzr
BL Die Hard
Hmm sorry. I intended to link it. Here it is:
https://forums.bunsenlabs.org/viewtopic.php?id=1256
Also, I still kind of feel like you are gonna want to translate this into /etc/fstab but I could be wrong! Let me know how it works out for you or if you need any help. Whether you call it a tunnel or not, systemd is gonna see it as a network mount, I think.
#6 2016-04-13 23:49:03
Peregrino69
Sorry HoaS. I copied your script exactly, and didn't work.
tknomanzr, thanks for the tip smile This one isn't for mounting remote FS, just strictly for SSHing from one network to another using a middleman. But I'll keep that in mind, it'll be useful elsewhere smile
#7 2016-04-14 06:22:16
Yeah, I didn't really think it would work OOTB, I cobbled that together in about two minutes big_smile
EDIT: try changing "Type=oneshot" to "Type=dbus" (sorry, I just can't help myself sometimes)
"didn't work" is a bit vague -- if you have a look at the output of:
systemctl status raspitunnel.service
sudo journalctl -u raspitunnel.service
You will be able to see how it fails and figure out how to get it working, if you're interested.
Alternatively, use:
sudo systemctl enable rc.local
I think this should allow you to use the old-style scripts in /etc/rc.local
#8 2016-04-14 12:14:30
Peregrino69
Thanks HoaS. I should know better than saying "didn't work"...
I'll check these when I get my RasPI running again. Installed OpenVPN server, after which it won't accept SSH access anymore...
#9 2016-04-18 17:25:38
Peregrino69
Resolved by simply putting the command to crontab.
@reboot /home/pgrino69/scripts/raspitunnel.sh
I first misplaced the script by doing nano /etc/crontab, which worked as well. /etc/crontab is a system-wide crontab file. Out of curiosity, what's the actual diff by editing that file instead of doing crontab -e?
