#41 2018-02-15 21:11:31
grobister
Re: February 2018 screenshots
my clean shot from the lappy
#42 2018-02-15 22:01:39
mrneilypops
The BL Scrot.Moe Guy
Arch+dwm  cool
solarized gtk
ACYLS icons
wall- Mike Yukhtenko
dwm
dmenu
slstatus
st      urxvtc in this scrot
...dreaming of my winter sunshine holiday T-28 days...
#43 2018-02-16 01:04:31
Bit of distro hopping today - Xebian
#44 2018-02-17 02:48:13
obscurant
#45 2018-02-17 02:57:57
I really like that, is that openbox?  Would you mind sharing your themes and configs please?
#46 2018-02-17 07:48:55
obscurant
It's pekwm. Here's my dotfiles. I have an openbox version, though it's a slight variation of the screenshot's color scheme.
#47 2018-02-17 12:07:49
Helium-dev showing dnssec-trigger working in the systray:
https://forums.bunsenlabs.org/viewtopic.php?id=4620
#48 2018-02-17 13:32:02
Missed this somehow:
mrneilypops wrote:
I have tried the 'grsec' kernel and 'vanilla' kernel options.
I always get a kernel panic error...
Is that with the ISO image? Be sure to transfer using `cp` or `dd` as they have isohybrid images.
The installed system needs to have the filesystem module declared as a kernel command line parameter or it will panic on booting.
FWIW, I have the same problem with Void Linux on my hardware... :cry:
#49 2018-02-18 06:41:39
#50 2018-02-18 10:07:16
mrneilypops
@Head_on_a_Stick
Thanks for info.
Yes, ISO image.
I will try an install again soon.
#51 2018-02-18 23:16:21
How's your htoprc?
#52 2018-02-19 07:24:56
mrneilypops
@Head_on_a_Stick
I have used that config (or similar) in the past.
Thanks for the reminder.
#53 2018-02-19 21:41:01
jwm with jgmenu -
#54 2018-02-21 21:27:08
cog
Screenshot-from-2018-02-21-14-23-00.th.png Screenshot-from-2018-02-21-14-23-07.th.png Screenshot-from-2018-02-21-14-25-08.th.png
I ripped Ubuntu's new theme a new one.
#55 2018-02-22 11:46:58
(Blender) Wallpapers here.
#56 2018-02-22 22:16:41
mrneilypops
Devuan Ascii beta [2018-Feb-14]
gtk/xfwm4 theme 'tetris'
icons 'paper'
Kernel updated to 4.14.0-0.bpo.3-amd64 [ascii backports enabled]
I am enjoying Devuan  cool
#57 2018-02-24 16:37:47
Fresh install:
Taken ~100MiB off the stock RAM total by disabling clipit & nm-applet, switching from terminator to urxvt, bash to mksh, NetworkManager to systemd-networkd and changing from LightDM to a console login, which also has the benefit of running X as the normal user (LightDM runs it as root, sadly).
Note also the trendy new Inconsolata monospace font, this is applied system-wide, even in Firefox 8)
#58 2018-02-24 16:55:43
mrneilypops
Devuan xanmod kernel 4.15.5-xanmod6 cool
#59 2018-02-24 22:43:46
#60 2018-02-24 22:54:58
mrneilypops
